General => General => Topic started by: amazonabby on May 21, 2009, 07:39:00 AM
Title: Fuses melting
Post by: amazonabby on May 21, 2009, 07:39:00 AM
1991 Mercury Capri XR2
My cooling fan does work. The fuse will not stay in place to tell it to turn on when it is hot. I can push in the fuse while driving to make it make a connection in the fuse box (not safe to hold a fuse in while driving and shifting) The fuse will get melted from me holding it in place (it doesn't blow it just melts the plastic and it looks like it is eating at the metal spokes on the fuses also). I know I could simply unhook my thermostat and that would make my fan come on when the car is on but than I run the risk of burning up the fan motor. Can I wrap the fuse in foil to make it have a better connection? Can I shove a second fuse in there to wedge it in place? Can I install a toggle switch so I can manually turn the fan on when it gets up to temperature? Please help I live in Florida and it is not fun driving with the heater on while holding a fuse in place and shifting.....
Please help this is driving me crazy.
Post by: Gostlrs on May 21, 2009, 05:52:00 PM
check your fan relays, and shoot the wires to make sure there is not a short. my guess is on the fan relay because it is melting the fuse not blowing it. either way you need to fix it ASAP. dont use your foil technique
Post by: amazonabby on May 22, 2009, 02:17:00 AM
I read yesterday that I could just bend the prongs and put it back in. I tried it yesterday and it seems to be working. I will let you know if it starts messing up again.
