April 25, 2024, 06:22:49 PM
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
General
General
Rim bolt pattern???? 4x100 or 4.x114.3????
« previous
next »
Pages: [
1
Print
Author
Topic: Rim bolt pattern???? 4x100 or 4.x114.3???? (Read 14476 times)
randyshear
Full Member
on:
June 02, 2009, 10:22:00 PM »
Does anyone have the correct rim bolt pattern for the N/A capri?
-Randy Shear
Old-Timer
Reply #1 on:
June 03, 2009, 08:45:00 AM »
Hey Randy! It's the same for all Capris. Gus
randyshear
Full Member
Reply #2 on:
June 03, 2009, 08:49:00 AM »
Ok, I thought it might be.. Which bolt pattern is it though? I'm looking for rims today..
-Randy Shear
STE_6000
Old-Timer
Reply #3 on:
June 03, 2009, 10:05:00 AM »
stock wheel is 4x100 14" wheel tires should be 185/60/14
you can go 205/50/15, 214/40/16, 205/40/17, or 215/35/18.
17 and 18 you are pushing it as there might be so rubbing on the read strut if you get the wrong offset. I have 17s on my capri.
Anthony
-Tinted Windows 20%
-Volant Cold Air Intake
-Corsa Exhaust
http://teamcapri.com\
\" target=\\"_blank\\">
Administrator
Old-Timer
91 BPT AWD Capri & 1991 XR2
Reply #4 on:
June 03, 2009, 10:12:00 AM »
Anthony,
the stock lug pattern is 4x114.3. 4x100 will not fit the capri.
STE_6000
Old-Timer
Reply #5 on:
June 03, 2009, 10:16:00 AM »
whoops, just measured my bolts >< cause after i posted it, i thought it didnt sound right.
Anthony
-Tinted Windows 20%
-Corsa Exhaust
Old-Timer
Reply #6 on:
June 03, 2009, 10:40:00 AM »
Hey Randy! There's been a bit of discussion in the past over wheel and tire combos. If yougo with a set of H&Rs it will tighten what will fit, so be careful in choices. I have on two '91s 15-6 wheels with 195-55 tires. both cars also have H&Rs. One car's wheels are factory '94 XR2 and the other aftermarket wheels. No clearance problem on either. some other forum members have 16inch and 17inch wheels. Get comments from them as well. Gus
STE_6000
Old-Timer
Reply #7 on:
June 03, 2009, 10:42:00 AM »
i dont know about h&r, but i have ground control coilovers with a 2" drop.
Anthony
-Tinted Windows 20%
-Corsa Exhaust
Old-Timer
Reply #8 on:
June 03, 2009, 04:25:00 PM »
17s on 205/40/17
no problems as all.
yen
Full Member
Reply #9 on:
June 03, 2009, 05:12:00 PM »
4 x 114.3 stud pattern
205/45/R16
1.25" drop on Lovell springs, koni shocks, still retaining original strut and perch hardware.
Severe scrubbing on wheel arch panel (front and rear) on tight sweeping turns +60Km/h
It literally took me months to find wheels to suit the car.
Would've taken a weekend if we were running 4 x 100 PCD
EDIT
major lapse of WTF
1990 Ford Capri
1.6L SOHC
Yuri
Old-Timer
Reply #10 on:
June 03, 2009, 06:15:00 PM »
144.4?
randyshear
Full Member
Reply #11 on:
June 03, 2009, 06:19:00 PM »
I have never heard of 144.4???
-Randy Shear
yen
Full Member
Reply #12 on:
June 03, 2009, 06:22:00 PM »
4 x 114.3
Sorry guys, got a case of scatter brain and lethal does of caffine.
Thanks for pointing that out
1990 Ford Capri
1.6L SOHC
Print
Pages: [
1
« previous
next »
General
General
