Author Topic: rpm idle  (Read 8051 times)
moot
    • http://www.cardomain.com/ride/3338493
rpm idle
« on: May 27, 2009, 05:21:00 AM »
anyone know what my rpms should be sitting at an idle i assumed over 1000 but idk about these cars also when i push on the gas it like stops for a second then the rmps go up it like stalls for a sec then vroom lol
rpm idle
« Reply #1 on: May 27, 2009, 10:01:00 AM »
FSM recommends 850-950 I think, I usually idle between 950 and 1000
moot
rpm idle
« Reply #2 on: May 27, 2009, 02:04:00 PM »
thanks rocket i usualy wouldnt have asked but it always sounds like its going to die so any suggestions about the lag? or is that just turbo lag sry first turbo
rpm idle
« Reply #3 on: May 28, 2009, 04:28:00 PM »
950 rpm, checked the car bible....
ill post a thread on how to defeat turbo lag and things ive done to reduce it on my car...
moot
rpm idle
« Reply #4 on: May 28, 2009, 05:12:00 PM »
have you posted it yet/?
rpm idle
« Reply #5 on: May 28, 2009, 05:13:00 PM »
double check the intake pipes, mine did the same thing and i found the plastic pipe had a split in it causing it to leak
moot
rpm idle
« Reply #6 on: May 28, 2009, 05:20:00 PM »
been trying that cant seam to find any though
rpm idle
« Reply #7 on: May 28, 2009, 05:37:00 PM »
not yet, ive made 4 new threads today and lots of pics,,, but i will sometime...
