I found a little corrosion on the distributor cap lead, I cleaned it off and its an improvement but I am still having problems. I have an hour drive to work everyday (south florida) and in the mornings it drives fine but about 30 minuets into my drive home I starts giving me problems. it starts sputtering on acceleration and soon after, it gets to the point where if I give it any gas above 2k rmp it starts sputtering and cutting out to the point where it is almost not drivable. It always happens around the same spot on my way home and it has to do with the heat. for example it started sputtering a little around the usual spot but I got hit with a rain storm (which lowered the temp) and it went away. when I first start the car it idles around 2k but settles down soon after. I have noticed on hot days when I push the clutch in to come to a stop, my idle dips down a bit low and recovers.my next step is replacing the cap and rotor? unless you guys have another idea? ignition module maybe? -thanks
