Author Topic: TPS  (Read 8418 times)
Trackerrrr
TPS
« on: October 21, 2018, 05:55:40 PM »
I've been trying to find cheap alternatives to our hard to find TPS units and I've come across a few part numbers that MIGHT work with some modifications.
Original Ford part is CXE 1329.
Alternatives:
Intermotor TH338. Looks identical to ours EXCEPT the mounting ears are reversed. Could be made to fit with a few pieces of thin aluminum or steel shim.
Drawback is that these came on the '86-'87 626 so they aren't too common.
« Last Edit: October 26, 2018, 11:19:42 PM by Trackerrrr »
Chris
Retired Air Force MSgt
Re: TPS
« Reply #1 on: October 22, 2018, 10:42:41 AM »
Thanks, Jack Byrd
Re: TPS
« Reply #2 on: October 22, 2018, 04:04:38 PM »
It's probably also possible to rebuild the stock unit with a new potentiometer inside
Re: TPS
« Reply #3 on: October 24, 2018, 12:45:54 AM »
The Beck/Arnley Throttle Position Sensor 1580909 is from manual transmission equipped BG series cars. The 3 wires are not electrically compatible and won’t work on the Capri because it doesn’t have a potentiometer inside, It’s nothing more then a pair of switches. One switch says the throttle is closed and the other says it’s full open.
Trackerrrr
Re: TPS
« Reply #4 on: October 26, 2018, 11:19:08 PM »
Thanks for the info, I'll delete that one.
Chris
