April 19, 2024, 11:37:55 PM
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Tech, Repairs, Upgrades
Capri XR-2 89-94
Miata turbo question
« previous
next »
Pages: [
1
Print
Author
Topic: Miata turbo question (Read 2210 times)
87blacklantern
Newbie
1991 xr2
on:
August 02, 2018, 01:40:36 AM »
Does any one know if Miatas have the same exhaust manifold bolt pattern as either a xr2 or standard Capri's.. Im just wondering Because I've read so far many parts are similar engine wise with the 1.6l and if so could use Miata 1.6l turbo kit or at least manifold
Sr. Member
91 BP Capri GT
Re: Miata turbo question
Reply #1 on:
August 03, 2018, 04:57:12 PM »
They do use the same bolt pattern.
The problem with the miata turbo manifolds is that they position the turbo to high.
87blacklantern
Newbie
1991 xr2
Reply #2 on:
August 05, 2018, 12:30:25 AM »
Ok that makes sense because are turbos site real low off the engine huh. But it would work just have to figure out hood and line problems then
Sr. Member
91 BP Capri GT
Reply #3 on:
August 06, 2018, 02:29:38 PM »
You're going to have more issues then just hood clearance. The stock B6T manifold puts the turbo underneath it and keeps it close to the side of the engine.
The Miata turbo manifold locates the turbo off the side of the manifold. This moves the turbo too far forward and it won't fit behind the radiator.
Why not use the XR2's B6T manifold?
Administrator
Old-Timer
91 BPT AWD Capri & 1991 XR2
Reply #4 on:
August 06, 2018, 09:44:22 PM »
The Miata is a RWD car with a different engine configuration, they have a frame rail to deal with. We have a radiator and a hood to deal with.
It's possible to modify a Miata manifold to suit, if it does not fit as-is
Print
Pages: [
1
« previous
next »
Capri XR-2 89-94
