Pages: 1 2 [3] 4
Author Topic: My first Capri, 1991 N/A  (Read 92871 times)
Re: My first Capri, 1991 N/A
« Reply #30 on: November 27, 2018, 03:09:07 PM »
Dang, bad luck guy.
JB
Trackerrrr
« Reply #31 on: November 27, 2018, 03:23:03 PM »
Dang, bad luck guy.
JB
Probably wasn't a good idea to buy the cheapest head gasket off Amazon. :P
Chris
Retired Air Force MSgt
« Reply #32 on: November 28, 2018, 03:41:13 PM »
I've had an uber-cheap gasket blow out on me before.
Did you get the head surfaced?
Trackerrrr
« Reply #33 on: November 30, 2018, 02:54:07 PM »
No, I didn't. This is the dirt cheap project and I didn't want to spend the money. I'll check the head with a straightedge and feeler gauge when I get it off again. :P
Chris
« Reply #34 on: December 01, 2018, 04:18:43 PM »
A piece of glass plate with fine (600+ I think?) sandpaper will help clean up the head surface, as a budget option. A googlin' will yield detailed information on the technique.
Best of luck :)
« Reply #35 on: December 01, 2018, 09:38:36 PM »
I googled that. Great tip! Thanks Rocketman!
Trackerrrr
« Reply #36 on: December 02, 2018, 10:37:19 PM »
Welp, turns out it WASN'T the head gasket after all. The residue in the intake from the pcv combined with heat and injector spray turned into a tarry mess that stuck to the valve stems and valve seats which caused them to stick. Used some brake cleaner to start cleaning the intake and valves and it seems to work well.
Chris
Trackerrrr
« Reply #37 on: December 02, 2018, 10:40:27 PM »
Also pulled ALL the old fuel lines and heater core lines to replace. Used compressed air to blow the fuel supply and return lines clear.
Chris
Trackerrrr
« Reply #38 on: December 02, 2018, 10:43:02 PM »
Also found the coolant passage through my IAC is plugged up so this is gonna be another challenge to fix.
Did get the gas tank cleaned out really good I think compared to what I started with.
BEFORE
AFTER
« Last Edit: December 02, 2018, 10:51:47 PM by Trackerrrr »
Chris
« Reply #39 on: December 03, 2018, 02:54:51 PM »
That's quite the revival you got going there.
Trackerrrr
« Reply #40 on: December 04, 2018, 05:45:52 PM »
I did something similar several years ago with a 1983 Ford F-350 CrewCab dually longbed. Everything on the truck was broke, bent, or otherwise gakked up. Got it for cheap but it cost me a lot more to fix it up and make reliable.
Chris
« Reply #41 on: December 05, 2018, 04:01:54 PM »
My first Capri was a similar project.  Guaranteed not to crank, start, run or stop....lol
Trackerrrr
« Reply #42 on: December 06, 2018, 10:27:40 PM »
I will persevere and she will be back on the road soon.
Chris
Trackerrrr
« Reply #43 on: December 07, 2018, 12:10:12 AM »
Ok, got the IAC coolant passage unplugged tonight. I had to drill small holes in the passage plugs and one in the lower elbow. Then I ran a small gauge wire thru each and got the gunk to break loose. I'll plug the holes with JB Weld, beats spending $600 plus for a new IAC.
Chris
Trackerrrr
« Reply #44 on: December 07, 2018, 12:12:53 AM »
I'm gonna get this thing back together in the next few days and fire it up....again.....
« Last Edit: December 07, 2018, 12:14:47 AM by Trackerrrr »
Chris
Pages: 1 2 [3] 4
