Author Topic: 1992 Capri n/a-1991 Capri XR2 swap  (Read 6107 times)
Shagdasty
« on: November 12, 2008, 12:13:00 PM »
Hi
I have a 1992 Capri n/a 97,000 mi. it's one of my daily drivers. I just picked up a 1991 Capri XR2 that 129,000 mi. it was wrecked on the right front. The guy I got it from sold it to me thinking the motor was trash. I just got it running and it seems to be in good shape (other than the wreck and the parts the guy removed)
I'm looking for info so that I can make a swap. I have noticed the n/a has the same wiring harness. But will the instrument cluster and turbo parts plug in and work? If the XR2 wasn't wrecked so bad I would swap the other way.
Any information or websites you could provide would be greatly appreciated
Thanks
Shagdasty
1992 Capri XR-2
1991 Capri XR-2
1992 Capri n/a
2005 F150 Lariat Supercrew
« Reply #1 on: November 12, 2008, 01:54:00 PM »
Hey Shaggy! Though I don't know this to be a fact in our Capris' case, the automakers generally make "one" wiring harness for a model of car. They make it to fit all options and just don't use the unneeded plug sets. Thats why when one checks under their hood and sees extra plugs they don't have the option that uses them. One can have a car with manual windows and door locks but the plugs are there in the harness if you want to later convert to electric. Anotherwards, Pull that Turbomotor and transaxel out and transplant it. The plus for the turbo conversion are there and are the least of your worries.  Good Luck and let us know how you did.  Gus
Shagdasty
« Reply #2 on: November 12, 2008, 02:15:00 PM »
Thanks Gus
So you feel the instrument cluster should be plug-n-play.
Any thoughts how to check the operation of the Turbo with out driving the car?
1992 Capri XR-2
1991 Capri XR-2
1992 Capri n/a
1992xr2
« Reply #3 on: November 12, 2008, 02:55:00 PM »
Try grabbing the shaft on the intake side of the turbo and moving it around. If there is any perceptable play it's probably near dead.  You can use a bike tire hand pump to check the action of the wastegate.
\\\'90 Civic Si
Boost in the near future.
drbob
« Reply #4 on: November 13, 2008, 07:28:00 AM »
looks like you were writing prOn, get you mind out of the gutter and put it under the hood.
AUSTRALIAN Shepherd
« Reply #5 on: November 13, 2008, 12:30:00 PM »
Hey Shaggy! Instrument cluster is plug-n-play  Gus
Yuri
« Reply #6 on: November 14, 2008, 01:46:00 AM »
you're going to want to swap nearly erverything from the xr2 into the n/a...every part of the drivetrain is beefier on the xr2. Someone on the forums here has a list of what all is different... Depending on the damage to the xr2, it might just be easier to use the n/a as a parts car and to fix the xr2.. how bad is the damage?
D22A
« Reply #7 on: November 19, 2008, 10:03:00 AM »
I meat one guy who has XR2, he is like 45 50 year old and did not care obout cars and I looked under car and there is everything same, brake are the same, only diffrent are sway  bars and engine   :D    , meybe shocks to I don't know.
take the sway bar from Xr2 and put on NA,change angine, transmision and  ECU I think that's all
I meant boot staf and all that staf, radiator is the same
1996 MT 3000GT LS
1993 CAPRI n/a
« Reply #8 on: November 19, 2008, 10:38:00 AM »
« Reply #9 on: November 19, 2008, 01:12:00 PM »
Hey D! I think Rocketman is glaring because you don't pay much attention. I realize you must be broke and can't afford the payments on attention. But the entire drivetrain is different between an N/A and an XR2. Yes you could bolt just the engine in place but the transmission and axles and brakes are all bigger to withstand the increase in horsepower and stopping the car.  Gus.
D22A
« Reply #10 on: November 19, 2008, 01:23:00 PM »
I did not read other peoples posts(at this time)
But i will take pictures of my brakes and then I will show you Xr2 picture and let see if you see difference, I will go and take wheel of now and I will put pictures in 15 minutes
1996 MT 3000GT LS
1993 CAPRI n/a
« Reply #11 on: November 19, 2008, 01:51:00 PM »
Hey D! you're not gettin it. Your car won't be an abnormality.  Gus
D22A
« Reply #12 on: November 19, 2008, 02:14:00 PM »
there is front brakes + shock
1996 MT 3000GT LS
1993 CAPRI n/a
D22A
« Reply #13 on: November 19, 2008, 02:16:00 PM »
1996 MT 3000GT LS
1993 CAPRI n/a
D22A
« Reply #14 on: November 19, 2008, 02:24:00 PM »
1996 MT 3000GT LS
1993 CAPRI n/a
