Pages: 1 2 [3]
Author Topic: Car stumbles around 2800-3200 RPMs  (Read 12267 times)
blackhandbeagles
    • 91 xr2
Re: Car stumbles around 2800-3200 RPMs
« Reply #30 on: May 22, 2017, 02:24:43 PM »
My problem was indeed the VAF.
Rod Bacon
    • 1993 XR2
« Reply #31 on: May 22, 2017, 07:04:39 PM »
Awesome. I have a similar symptom, so will try a VAF. Can anyone confirm if the VAF is the same on the turbo and N/A models?
blackhandbeagles
    • 91 xr2
« Reply #32 on: June 07, 2017, 03:40:58 PM »
OK, the problem started to come back. More cutting out under mild throttle. Ran half a bottle of seafoam through the gas tank. Running good so far.
Read another thread that said the baffles under the valve cover could be causing the issue.
http://teamcapri.com/forum/index.php/topic,3936.0.html
« Reply #33 on: June 07, 2017, 09:00:05 PM »
Rod, they are different. Check RockAuto's part numbers. Makes sense since turbo volumes flow more.
Rod Bacon
    • 1993 XR2
« Reply #34 on: June 15, 2017, 09:44:45 PM »
Cheers. My problem turned out to be ignition components. Replaced everything and we're all good.
« Reply #35 on: June 15, 2017, 10:36:22 PM »
Enjoy! My XR2 is under the knife at the moment, pulled the head and found that the oil passage in the front by the timing belt was the leaker I was fighting for most of the last year. Cometic head gasket, ARP headstuds and a head check including valve seals is underway. Hope to get mine going in a few days as well.
JJ
« Reply #36 on: August 28, 2017, 12:24:28 PM »
blackhandbeagles: car still doing ok or is that stumble back?  sorry after posting that I hadn't been on the forums in months...
i have a much longer post here describing that same issue.  Mine happened to go away after a radiator replacement.. The mechanic also timed the car correctly. so not sure if it was timing, or perhaps ground related as there's a ground wire on/near the thermostat
i drove it for many months without the tps wire connected. that puts the ecu in a 'steady state' mode where it ignores most inputs and does the minimum to make car run. chased my tail on that one for a few years.
Pappy T
    • 91 base Capri
« Reply #37 on: August 28, 2017, 02:03:45 PM »
Hey Rod , what distributor parts did you get into to get rid of stumble ?? Having same issue with my '91 na . Thanks
Pages: 1 2 [3]
