Pages: 1 2 [3]
Author Topic: 94 N/A idles great but feels like rev limit or limp mode on acceleration  (Read 3958 times)
Pappy T
    • 91 base Capri
Thanks for that one Terrymetal, I did notice my temp gauge isn't working since I got it out of mothballs ... maybe it's been going on the fritz and finally pooped out , we'll find out next week or two fingers crossed .  Thanks again !
terrymetal
    • 1992 Mercury Capri Convertible, 1979 Ford Ranchero
Its no problem!!  I hope everything works out for you! My car runs horrible right now and the throttle cable broke yesterday. Never ends with these cars!!  Terry
Pappy T
    • 91 base Capri
Well , cleaned my temp sending wire and sender , not too grody , and temp gauge works again ! BUT , still have the sputters  :(
 Anyone want to buy a nice Capri ?!
The temp sender is not read by the ECU. It has its own sensor on the bottom of the intake manifold
Pappy T
    • 91 base Capri
Thanks Rocketman , I'll track that one down too !
Pappy T
    • 91 base Capri
Rocketman, did a little hunting around intake manifold , don't feel or see any kind of wiring . What should I be looking for ?  Thinking if I hadn't seen or noticed it before , could be my issue !? Thanks !
It's the sensor sticking out of the bottom of the intake manifold here.
Pappy T
    • 91 base Capri
Holy cow . Looks like a lot of fun to get that one ,, don't remember messing with that one before even when I redid all the hoses , hope that does it.
Big Thank You  .
terrymetal
They are a pain to get to and usually are corroded some and hard to turn out. If you have to replace it make sure the new one has thread sealer on it or put some on it. Makes it easier to install and less prone to leaks. Good luck! Terry
Pappy T
    • 91 base Capri
Wellll , got connector off and it was pretty clean , cleaned and reassembled it .. still doing it . A question I do have is with others in the same boat , does it sputter AFTER reaching temp or all the time , could rule out sensor ?
Also , my brake light on the dash stays on , the blue wire that comes out the bottom of fluid reservoir  I found was disconnected , the ONLY plug I found was on firewall but it has 2 different color wires coming from it , plug from fluid is blue , any ideas here ??
  Thanks again guys .
terrymetal
As far as I know. You would have to check the resistance of it to see if its within specs. It could go either way though from my experience.
chukT
Have you checked to be sure the cam timing is still correct? Maybe it slipped a tooth, or the crankshaft pulley is loose.
Pappy T
    • 91 base Capri
Thanks Terry, a bit more than I want to dig into for awhile , not in the mood for removal !  chukT , Will have to check into that , Thanks to both of you for the insight .
Pages: 1 2 [3]
