Pages: 1 [2]
Author Topic: Capri with 323GTX drivetrain  (Read 18465 times)
Kenter
    • 93 Mercury Capri
Re: Capri with 323GTX drivetrain
« Reply #15 on: March 20, 2016, 11:29:55 PM »
Yes! Snake that is what I was hoping to get from rocket thanks for the digging hopefully with any luck I will be starting this this summer.
« Reply #16 on: March 21, 2016, 12:24:06 AM »
Glad i can help, if i get enough hours, i plan on going the same route but ill be going a little bit differently than you guys. My plan is to get a 1.8l VVT Miata motor and the 2.0l stroker kit. That way if i ever wanna swap my turbo on their i can make big gains. As i get more info that will help us both ill post links.
Kenter
    • 93 Mercury Capri
« Reply #17 on: March 31, 2016, 12:22:10 AM »
That'd be cool snake! Maybe I'll have to research that.  ;D I have another open question for anyone who wants to answer. Is the gears in the fwd trans the same as the gears in the awd trans? I've got a slight second gear grind in the gtx, and I want to believe that it's from the clutch being pretty much rubbish in the gtx. Because if I take it easy it won't grind, but if I'm at all sloppy it will grind some.
« Reply #18 on: March 31, 2016, 10:32:28 AM »
Second gear grinding is a very common issue on the GTX tranny that has not been treated nicely. At this point a rebuild should be on the list of things to do especially if tranny is out of the car.
« Reply #19 on: April 05, 2016, 10:31:54 PM »
Any progress?
« Reply #20 on: June 21, 2016, 02:22:25 AM »
Bump?
« Reply #21 on: June 22, 2016, 12:13:56 AM »
The reason I brought up the top was its connected to the floorpan.
The top is NOT connected to the floor pan....
« Reply #22 on: June 22, 2016, 03:35:43 AM »
Wait really from what it looks its bolted directly to the floor/trunk pan?
« Reply #23 on: June 22, 2016, 08:29:39 PM »
Nope it bolts pretty high up on the column behind the door jamb. It's only held on by 4 bolts
Pages: 1 [2]
