Drive onto some ramps, put a big piece of cardboard box down, slide way under there (the cardboard helps you slide and keeps you cleaner) with a couple of 10 mm (is that right everyone?) wrenches. Have someone jiggle the shifter and you will see where the slop is, remove the bolts, put in the bushings, and you are done. not any more complicated than that...
