Pages: 1 ... 27 28 [29] 30 31 ... 36
Author Topic: What did you do to your Capri today?  (Read 228623 times)
Skunkwrkz
« Reply #420 on: July 17, 2019, 11:21:28 PM »
Plugs, wires, rotor and cap for the red car.  Set of Mercedes SLK seats for the white car.
Fun times in the heat getting those seats Saturday....Glad someone brought that motorcycle/UPS battery so we could power them.
Got that right, gotta get me one of those for when I start the installation.
Can use mine. I have a whole box of em. I'll bring it this weekend.
« Reply #421 on: July 21, 2019, 08:07:43 AM »
New wires, plugs, cap and rotor.  Didn't realize it could run this much better.
« Reply #422 on: July 24, 2019, 08:04:41 PM »
Replaced the worn out steering wheel on my red car.  Thanks David Young.
fastbrianman
    • 93 Capri 1970 442 1975 Trans Am 94 Corvette
« Reply #423 on: August 16, 2019, 10:29:55 AM »
I had added an XR2 spoiler previously,  I finally put new struts on the trunk lid to hold it open.  Got them from Rock Auto from the list of items they are discontinuing/closeout.
« Reply #424 on: August 16, 2019, 11:09:30 AM »
Need to check that out, I need struts too.
« Reply #425 on: August 18, 2019, 05:30:23 PM »
An XR2 showed up at the local Pull-A-Part and scored some good parts.  IAC, brake master cyclinder, two door pulls, a glove box with a good latch, a top latch, excellent trim piece from the convertible top cover, excellent center console, both pieces, assorted relays and all the big fuses.  A little under a hundred bucks.  Good day.
« Reply #426 on: September 11, 2019, 03:54:34 PM »
Got white corner lenses from Oz.  Thanks Ben Rogers.
« Reply #427 on: October 01, 2019, 10:21:09 AM »
Had to replace the driver window regulator.  Thanks James Whitt.
Skunkwrkz
« Reply #428 on: October 27, 2019, 11:15:20 PM »
Has anyone done the 5th gear conversion from Roo-Sport?  I have the kit and I'm thinking about making that the weekend project.  Any advice out there?  Is there a gasket on the tranny end cap?
I have. I suggest using a stout impact wrench as it will make it so much easier and I would presoak both nuts with either PB Blaster or a mix of acetone/antifreeze (actually works better than PB Blaster)
There was a great step by step on 626.net, but it's down it seems right now.
Here's a great YouTube video that basically shows you how to access and change the gears in a g-series. It's from the same family of tranny's. You will need a 27mm and a 32mm socket for the nuts. I suggest buying new pinch nuts if the kit didn't come with them.
[url][/https://www.youtube.com/watch?v=yJPVmCzTayYurl]
Skunkwrkz
« Reply #429 on: October 27, 2019, 11:44:24 PM »
Finally got around to mounting new X-Drilled rotors, Stainless lines, rebuilt calipers and sourced some Stop Tech street pads that came with all new hardware. Good stuff and they look great! Nice, firm, brake pedal now and good modulation. Bedded them in this evening. I’ll see what they are like in the mountains tomorrow with top down.
« Reply #430 on: October 28, 2019, 09:19:19 AM »
That is a great looking setup.  You're going to be able to tame the Dragon with ease.
« Reply #431 on: October 28, 2019, 11:34:40 AM »
My power windows quit working and I had to rebuild the driver's switch.  Thanks to whoever it was that posted the info about this process.  I didn't need it at the time, but put it in the memory bank.  That's the great thing about this forum.
Thanks again, Jack Byrd
Skunkwrkz
« Reply #432 on: October 28, 2019, 09:00:11 PM »
Thanks for the compliment Jack. I think me and you need to just make that journey....Back to the Dragon  8)
« Reply #433 on: October 29, 2019, 08:57:44 AM »
You are right about that, wish I could make it this weekend.
« Reply #434 on: November 26, 2019, 08:24:28 PM »
Finally got the front turn signal / parking light sockets rebuilt and operational on my 92 xr2. Now to get this thing inspected and back on the road!
