Pages: 1 ... 9 10 [11] 12 13 ... 36
Author Topic: What did you do to your Capri today?  (Read 232700 times)
Mike.Sasich
    • Pantera , Porsche 550 replica,91XR2 ,92XR2 ,F350
« Reply #150 on: June 23, 2015, 08:43:40 PM »
The 91 got new shoes today ! :)
"It Shows" (Captain Ron)
supercowmoo3
« Reply #151 on: June 24, 2015, 03:58:36 PM »
I'm doing a manual transmission flush and refilling it with synthetic 75w 90 gear oil instead of the atf that is so thin it seems so have started making my gears whine more and more. Hopefully the gear oil will solve that problem.
NomakeWan
    • 93 Capri XR2
« Reply #152 on: June 24, 2015, 06:37:38 PM »
What a coincidence, doing that with Pennzoil Synchromesh on Friday myself!
« Reply #153 on: June 25, 2015, 04:01:34 PM »
Discovered why my transmission went out a couple of weeks ago.  No transmission fluid after the clutch was replaced a week before that.  Mechanic wouldn't accept any responsibility for the dry transmission.  We're going to talk about it again next week.  I got two quarts of Synchromesh to fill the new transmission when they get it in.
Jack Byrd.
« Reply #154 on: June 25, 2015, 04:46:58 PM »
Jack Byrd.
He doesn't want to admit it because it costs him $$. You pull the axles fluid comes out. If for some unknown mystery it was dry before its still his job to top the tranny fluid off. If there was a leak afterwards it was from a damaged axle seal. There's no way around it he screwed up. He needs to suck in his pride and man up.
NomakeWan
    • 93 Capri XR2
« Reply #155 on: June 26, 2015, 03:22:08 AM »
Good luck with that. I had a mechanic replace the rack only to have the power steering pump fail 10 miles later (which we both know was because they didn't fill the system properly). They put in another pump and that one failed two weeks later along with the 'new' rack. That was back in the first week of April. It's about to be July and I'm still trying to get them to pay up. They both refuse to admit it was their fault and refuse to reimburse me.
As for the two quarts, according to the service manual for the G-series transmission the capacity is 3.4 quarts.
« Reply #156 on: June 26, 2015, 05:41:23 AM »
My service manual for the F series transmissions has the oil capacity as 2.83 quarts.
NomakeWan
    • 93 Capri XR2
« Reply #157 on: June 26, 2015, 08:09:15 AM »
Oh whoops, he's got an NA. Then yeah, 2.83 Qt. :)
« Reply #158 on: June 26, 2015, 08:57:45 AM »
Funny you mention that, they replaced the axle seal because they were afraid they might leak.
Jack
Grimsleeper
    • 1991 Capri XR2
« Reply #159 on: June 26, 2015, 12:59:20 PM »
All this transmission talk.  I'm doing the 5th gear conversion today.  Can't wait to try it out.  I'll make sure my tranny is full of gear oil before I drive it.
« Reply #160 on: June 27, 2015, 08:35:25 AM »
Excellent move.... :)
Jack
Grimsleeper
    • 1991 Capri XR2
« Reply #161 on: June 27, 2015, 11:49:09 AM »
Just took the XR2 out for a test drive on the new 5th gear set.  That's the best mod I've done so far.  Much nicer at highway speeds.  75 mph at 3200 RPM.
NomakeWan
    • 93 Capri XR2
« Reply #162 on: June 27, 2015, 02:51:03 PM »
Just replaced the valve cover gasket and all that, time to let 'er sit while the RTV cures so I can finish reassembly and get back to driving.
One weird thing, though. I took the car to Mazda to have them do the manual transmission flush. I gave them 4 quarts of Pennzoil Synchromesh. They gave me back 2.5 quarts. The transaxle capacity is listed at 3.4 quarts in the service manual. Uh...what? ???
« Reply #163 on: June 27, 2015, 07:58:09 PM »
I'd be asking them why?? Something isn't right there.
Why didn't you just buy a valve cover gasket set?
NomakeWan
    • 93 Capri XR2
« Reply #164 on: June 28, 2015, 02:23:48 AM »
I did. You still use RTV on a few of the corners, or at least the factory sure did.
