Pages: 1 2 3 [4] 5 6
Author Topic: BP Swap  (Read 72533 times)
Re: BP Swap
« Reply #45 on: August 17, 2016, 08:34:08 AM »
The F series tranny is more then strong enough to handle a N/A BP.
Re: BP Swap
« Reply #46 on: August 17, 2016, 10:13:03 AM »
Agreed but it will all depend on how you treat it. You will need to remember the bp tilts 11* to the front and using the f series will mount it straight up. The oil pan is designed for the tilt. Talk to Matt on this but should not be  an issue.
Re: BP Swap
« Reply #47 on: August 19, 2016, 11:05:16 AM »
If you’re dumping the clutch at 5k+ rpm  to do burnouts or doing flat footed shifts, the F-series tranny won’t live very long. Then again the G-series won’t last much longer under those same conditions either…LOL
The oil pan tilt isn't a problem, I've never had my oil pressure drop below 30psi after 70K+ miles now.
Re: BP Swap
« Reply #48 on: August 19, 2016, 12:58:29 PM »
Yea, I really dont hoon my car. I guess ill just stick with the f-series, and then just switch to the g-series whenever I get the GTX parts.
Re: BP Swap
« Reply #49 on: August 22, 2016, 08:23:27 AM »
The issue with the oil pan, what with it being cast aluminum, the back hangs down real low. I think I scraped mine once or twice.
It's a risk to hit stuff with it, it will shatter and not dent like a stamped pan might.
My mounting situation may be different than other swaps though
Re: BP Swap
« Reply #50 on: August 22, 2016, 10:42:40 AM »
There’s definitely a mounting difference between our cars…LOL
The back of the oil pan does hang somewhat lower, but it’s still higher up than the tranny crossmember and I still have the original bottom debris/splash shields installed that cover the oil pan too.
A level also shows that my engine is tilted forward roughly 4 degrees.
Re: BP Swap
« Reply #51 on: August 22, 2016, 02:23:33 PM »
Just got back from the junkyard all the Escort GTs had their valve covers or heads taken.
Do you guys have any tips for checking a junkyard engine other then compression check, and crank turn? Also is there any aftermarket engine mounts? I cant seem to find any.
Also quick question will this suspension work? I didnt feel like starting a new thread for suspension stuff.  http://m.ebay.com/itm?itemId=191615757590  I see there is a model thats for the GTX, but would this be the correct model for our cars?
Also what happened with my Avatar? It doesnt show up on my phone at all.
« Last Edit: August 24, 2016, 07:55:38 PM by WashiestSnake »
Crapi Attitude
Re: BP Swap
« Reply #52 on: August 24, 2016, 03:52:05 PM »
You probably want to swap the clutch slave cylinder for one from an Escort or Protege, as the Capri one won't clear the engine face plate. I used the Capri slave mounted at a cockeyed angle because I'm cheap and lazy.
My slave cylinder blew out. Either the screwy angle did it in, or it was just another crappy part. I replaced it with an Escort slave, which fit properly. The piston rod was about 5/8" too long so I cut it down and ground he edges to sit in the piston dish. I drove 15ish miles around town so far, and it worked great.
« Last Edit: August 24, 2016, 03:56:14 PM by Crapi Attitude »
Re: BP Swap
« Reply #53 on: September 14, 2016, 10:10:20 PM »
Physically, the BP is about an inch longer than the stock 1.6L engine. This creates clearance issues. Also for this reason, the manifolds do not interchange. You will need a complete BP with manifolds.
http://www.neukin.com/Mazda_323_B6T_BP_Turbo_Manifold_p/mazdabpb6t323.htm
Why does this state it can fit either?
Crapi Attitude
Re: BP Swap
« Reply #54 on: September 15, 2016, 02:15:03 AM »
Maybe they make two versions. I seem to remember holding my B6 manifold up to the BP and not being remotely close to fitting.
Re: BP Swap
« Reply #55 on: September 15, 2016, 03:33:22 AM »
Going by what the link you provided, it sounds like they offer two different versions and weld the turbo flange you request on.
Re: BP Swap
« Reply #56 on: January 03, 2017, 07:07:56 PM »
Isnt the Escort G Series hydraulic? I swore I read something somewhere about that. What issues would be caused using the NA hydraulic system?
Re: BP Swap
« Reply #57 on: January 03, 2017, 09:58:31 PM »
They offer(ed) a version for each engine. Im not sure they make them anymore, interesting that the page is there - I thought they discontinued their manifold. They were $650 back in the day.
Yes, they're hydraulic, it should mesh nicely with the N/A manual trans system. Unless there's some large discrepancy with master cylinder bore sizes, you may need to upgrade it.
« Last Edit: January 03, 2017, 10:03:50 PM by Rocketman »
Re: BP Swap
« Reply #58 on: March 05, 2017, 01:18:50 PM »
Quick question, ill be using a remapped Evo8 ecu and wiring harness from BP Performance, how will this change my install? The whole reason I plan on using the Evo8 ecu is because the wiring is allready ready for C.O.P and im afwul at wiring.
Re: BP Swap
« Reply #59 on: March 05, 2017, 03:49:56 PM »
It shouldn't affect any mechanical aspects of the swap. They should be able to support you regarding the wiring.
Automotive wiring is simple!
