April 18, 2024, 08:38:08 PM
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Tech, Repairs, Upgrades
Non-Capri Usable Car Parts
broken headlight/window motors
« previous
next »
Pages: [
1
Print
Author
Topic: broken headlight/window motors (Read 5186 times)
mazdacapri
Newbie
on:
August 29, 2012, 03:16:00 PM »
I recently fixed my headlight motors and window regulator but they are now broken. i cleaned and lubed everything in the headlight motors but broke the threads holding motor to the linkage. went to the junkyard and got headlight gears and those armature coil things from a ford probe. turns out theyre not the same size. are there any cars that use the same plastic gear as the headlight motor gear?
I also tried to fix the window regulator. it worked for a little while but now its broken again. the problem is the plastic cable guide thing keeps tearing up the cables. is that plastic gear fixable? or is there a junkyard fix from another car?
mazdacapri
Newbie
Reply #1 on:
September 01, 2012, 08:34:00 AM »
I found some replacement cable guides from 95ish Mazda 626 in great shape at the junkyard
and theyre blue
. Still on the lookout for headlight motor gears from other cars that might fit.
Does anybody know if the driver and passenger side cable guides from the capri are reverse threaded from each other?
Old-Timer
Reply #2 on:
September 02, 2012, 10:44:00 AM »
Russ has rebuilt regulators.That will save you time and money in the long run. I have gone the route of working through these and should have just bought new or rebuit.
jfrrw92capri
Newbie
Reply #3 on:
October 08, 2012, 02:58:00 PM »
Anyone know where I can get new headlight motors without paying an arm or a leg, like any other model car that I can pull a pair off of?
Administrator
Old-Timer
91 BPT AWD Capri & 1991 XR2
Reply #4 on:
October 08, 2012, 04:08:00 PM »
They're Capri specific, I don't think anyone can get new ones anymore.
Administrator
Old-Timer
Reply #5 on:
October 08, 2012, 05:33:00 PM »
As Rocketman said, they are Capri specific, and are no longer available new.
Roo-Sport.com carries fully tested used units that are not that expensive....
503-919-4227
---Russ
Need parts?? Go to
http://www.Roo-Sport.com
Print
Pages: [
1
« previous
next »
