Pages: 1 [2] 3
Author Topic: Seats....  (Read 34390 times)
mazdaspeedcapri
Seats....
« Reply #15 on: December 21, 2012, 07:56:00 PM »
what about subaru? the mid to late 90s imprezas, those that ive found in upullits dont have alot of wear and tear , has anyone tried a pair of those
Jovani
Seats....
« Reply #16 on: December 22, 2012, 12:32:00 AM »
my gc8 impreza seats are okay nothing to brang for.. I have apc seats in my capri on custom fabbed rails an I love them. ebay has cheap seats if your looking for or anything new, if your in the used market look for fc rx7 buckets... I miss my fc now lol... or s2k and rsx seats.. they have pretty solid bolsters and also comfortable.. especially s2k's!
mazdaspeedcapri
Seats....
« Reply #17 on: December 25, 2012, 02:17:00 PM »
well the only reason i say this is cuz i happend to stumble across a really nice pair of factory sports seats in a 95 model awd subaru n/a with hardly any wear at a upullit, and also, has anyone ever seen an fc with a back seat, and i mean a factory installed back seat? cuz i found one in the same upullit.
Jovani
Seats....
« Reply #18 on: December 25, 2012, 11:36:00 PM »
The 2+2 option in fcs were to reduce insurance cost... kinda rare depending on what gen fc whether it be a s4 or s5.. all fcs can be swap to 2+2, they are all pre fabbed, unless convertible like mine. first generation rx7s hsd same option
Seats....
« Reply #19 on: December 26, 2012, 05:33:00 AM »
There is really nothing that is "bolt-on" that will fit the Capri, except Capri seats. Everything else will have to have mounts fabbed up.
Grab a tape measure and measure whatever you find at the PNP..If'll they'll fit in the space intended for Capri seats, you can make brackets, then there ya go....
Snigalfriz
    • 1991 NA Capri
Seats....
« Reply #20 on: January 07, 2013, 10:16:00 PM »
I am currently putting a set of seat from a 1995 Lincoln Mark VIII.  I have the passenger side in, and will be working on the drivers side in the next day or so.
1991 Mercury Capri 5-sp
1992 Mercury Capri 5-sp swap
1999 Ford Contour SE 24v v6
2003 Lincoln LS
2007 Saturn Outlook XE AWD
2014 Chevy Cruze LT
Seats....
« Reply #21 on: January 09, 2013, 04:13:00 PM »
I have to say that these were "bolt" in...
They came with universal sliders. They literally bolted to the floor without any modifications. Just drilled the holes and fit perfect.
Seats are checkers special with Universal Sliders
http://sell.lulusoso.com/selling-leads/613691/universal-seat-slider.html
Captain
Seats....
« Reply #22 on: January 09, 2013, 04:53:00 PM »
So this adapter replaced or add-on to fit?
91 Mercury Capri
Capritain @ Cardomain.com
Seats....
« Reply #23 on: January 09, 2013, 05:02:00 PM »
I dont have the photos of them drilled to the floor board any more
There are 2 "ribs" that they sit on & you just secure them there. Literally took me about 1hr to get them installed.
Captain
Seats....
« Reply #24 on: January 09, 2013, 05:39:00 PM »
drill to the floor board? arent they thin? the OEM hole is actually a soldered on bolt aint it?
91 Mercury Capri
Seats....
« Reply #25 on: January 09, 2013, 07:18:00 PM »
those ribs were thick enough and i used like 3/8 bolts make for sheet metal
Seats....
« Reply #26 on: February 21, 2013, 04:48:00 PM »
Working on fitting these seats now:
Theyre from a 1993 Honda Civic hatchback. Seem to be much higher quality sliders, plastic, adjusters, etc... also much lighter.
The sliders actually look like they might directly interchange with the Capri sliders, however the Capri is 16" between rails and the Honda seats are 17" between rails. I'll probably cut & weld the ears to make everything fit
grantduffield
  • TeamCapri Supporter
    • 1991 Capri (automatic)
Re: Seats....
« Reply #27 on: March 19, 2014, 08:15:12 PM »
Mazda Protégé seat swap.  Pretty simple job and the seats fit nicely.  I sheared off the mounting brackets on the mazda seats and then used some heavy duty "L" shaped aluminum across the front span of the seats to tie into the existing mounting bolt insets.  Then bolted the seats to the aluminum span.  I used flat aluminum between the rear mounts and bolted that down too.
http://i989.photobucket.com/albums/af15/grantduffield/photo3_zpsc172ceb2.jpg
http://i989.photobucket.com/albums/af15/grantduffield/photo2_zpse94e293c.jpg
http://i989.photobucket.com/albums/af15/grantduffield/photo4_zps9ab358a8.jpg
ReedStemen
    • '91 Capri
Re: Seats....
« Reply #28 on: March 22, 2014, 02:09:56 AM »
Audi TT heated leather seats. Sit nice and low.
-Reed
Re: Seats....
« Reply #29 on: July 13, 2015, 01:24:40 PM »
From a 1998 BMW 318i. Heated with about 6 positioning levers for great comfort. Heat switches fit into a '94 console where the power window switches were with a tiny trim to fit. Had to make some attachment brackets, but I love them.
« Last Edit: February 03, 2018, 09:31:53 PM by SHOwn »
Pages: 1 [2] 3
