Author Topic: RocketFlow VAF Adapters!  (Read 19288 times)
« on: February 17, 2011, 04:46:00 PM »
Another new product in the Rocketman lineup!
These adapters provide a smooth transition between the square VAF port and a 3"ID round so you can bolt on your favorite cone filter, or run custom piping for a fenderwell intake. These fit the XR2 VAF - but may also fit the N/A, I will check.
The cheap eBay adapters fit like crap (seen in the background) they have a round hole directly on the square port. This leaves an abrupt transition which is terrible for good airflow.
These are SOLID cast aluminum adapters, made by ME in the USA! (no cheap chinese crap here)
Asking $50 INCLUDING shipping to the lower 48. No gasket included, you can use gasket-maker or seal with a *thin* bead of RTV.
email me rocketman[AT]werbatfik.com for ordering info!
« Last Edit: June 09, 2014, 02:36:14 PM by Rocketman »
Heavensheros
« Reply #1 on: February 17, 2011, 06:20:00 PM »
is there anyway the newer made ones will have a cleaner outside look and smoother back plate, looks like the two halves are not aligned, but ill take one, i get paycheck tomorrow ill let you know!
1992 Capri XR2
RocketMan VAF adaptor
Accel wires
Irundium IX
2.5\\" Thrush exauhst
Rocket Chip
Rims
H&R Lowering Springs
Tuner FX Racing seats
Gauges w/ A-pillar gauge pods
Accel superstock coil
FMIC
« Reply #2 on: February 17, 2011, 06:23:00 PM »
There is only a very small misalignment on that one that I will be correcting before more are made.
I can grind one a bit smoother for you if you want
cj cooley
« Reply #3 on: February 19, 2011, 12:20:00 AM »
rocketman, do you think you might work up a version for the na capri? I know people have said that dosen't benefit the na as much as the turbo but i have been tinkering and think it definitely make a difference. Just the exhaust that i have opened up has made a major change in the get up and go! I am working through the same mods that I have always started with to improve my rides on land and water. Let me know what you think! also, what are you casting with? I make my living lately by salvaging(mostly copper and aluminum) and I could keep my eye out for high grade aluminum for you. Last year I recycled near 5 tons of it!
« Reply #4 on: February 19, 2011, 11:35:00 AM »
These might fit the N/A no problem - im trying to get ahold of one to find out. Either way I could probably come up with something for it if this doesnt work.
I have hundreds of pounds of aluminum here, I usually cast a high silicon AL, near A356 spec. I dont go through it fast with parts like these lol, but thanks!
I am however on the lookout for yellow brass & bronze, if you come across any I'm certainly interested.
cj cooley
« Reply #5 on: February 19, 2011, 06:04:00 PM »
I usually come across about 100 lbs a month or so during the summer when the scrap is plentiful. it is mostly electrical grade transformer yellow brass. I only have around 10# on hand right now. I like russ, have been laid off  for awhile so I use my contacts in construction to help me find good scrap for recycling to make ends meet. Let me know what you determine how the adapter might work, I would be interested in one for sure! I love to tinker and make things from scratch but the casting you do (the latches and adapters) is out of my skill level. I can only imagine how much I would have bothered you when i was moding my ski. Great admirer of your work and look forward to meeting you some day!
« Reply #6 on: February 26, 2011, 07:18:00 PM »
Thanks! I'll be at the Capri meet this summer so we can catch up then. If you're in the need of custom parts, I can quote it for ya. I too have been unemployed since 2/2010 and I'm trying to get my casting up & running to the point I can sustain myself.
As for the N/A VAF adapter: It has the same bolt pattern, but a totally different port shape. I can't believe how tiny it is! Hah. BUT- I'll be able to come up with an adapter for it. It will be a different style, but I can make it work.
Unknown ETA at this point, but I'll keep you updated!
David Young
    • 1993 XR2
« Reply #7 on: February 28, 2011, 07:00:00 AM »
Matt,
That glove door handle is out of site!!!
David
David A. Young
« Reply #8 on: March 01, 2011, 12:52:00 AM »
Glad you like it Dave!
Here's a rendering of what the N/A VAF adapter will look like:
« Reply #9 on: March 22, 2011, 07:36:00 PM »
AAAAAAnnnnd here's the final product:
This is for the N/A VAF
Heavensheros
« Reply #10 on: March 23, 2011, 03:37:00 AM »
looks great man !!! cant wait to see mine and take pictors !!
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
Heavensheros
« Reply #11 on: March 31, 2011, 10:55:00 AM »
ATTENTION !!! THIS ADAPTOR IS AWESOME !!!!!!!!!!!
here are the BEFORE pictures of the adapter that you can buy on EBAY !
notice how you can see where the air will hit on the sides and cause turbulence, this is bad because once the air is unsteady it harder to move,
not with the new adapter you get this
the air has a very smooth and clean place to go and the performance is MUCH better from that!
heres how it looks with my added touch :)
and how it looks on the car
I HIGHLY RECOMMEND THIS TO ANYONE !!!! WELL WORTH THE PRICE OVER THE EBAY ONE !!!
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
« Reply #12 on: March 31, 2011, 05:39:00 PM »
Hey, Josh: Nice fingernail polish in that first picture! That shade matches your car very well!!!
Heavensheros
« Reply #13 on: April 02, 2011, 06:15:00 AM »
HAHA i had madison holdthe flapper open i promise
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
shoeish
« Reply #14 on: April 06, 2011, 09:42:00 AM »
I'll bet you could sell these to the Miata guys...
